AutoCAD 2019 - Error 108097
diego.haberle
Observer Observer
diego.haberle
Observer
Observer
Good morning,
recently after the installation of AutoCAD 2019 on my desktop I had a series of problems:
1) When using the program after 4 or 5 minutes, the pointer stays freeze for 30 or 40 seconds and then it is normally activated again for another 4 or 5 minutes until the same thing happens again continuously. (I have a license in Corporate Network, but I have borrowed license for a week) I thought it could be an online check-up that did every certain amount of time but I don't think that is having borrowed license.
2) I recently observed that when starting AutoCAD in the command bar I get the error 108097 and I can't find what it is.
Does anyone know how I can solve it, without the answer being reinstalling it?
imadHabash
does this freezing issue happened in a certain CAD dwg file or in general ?
under what command procedure this error appeared ?
Imad Habash
pendean
Community Legend
Community Legend
Explore the many similar posts on the topic, try what they suggest: https://www.google.com/search?&q=autocad+modelling+operation+error+108097
Did you install the 2019.1.2 update yet? It is required, ABOUT command will confirm if you have it or not.
diego.haberle
Observer
Observer
The problem generally happens with any file
I don't know, from what I see it is random and I could not identify when I see that poster on the command line!
diego.haberle
Observer
Observer
>>Have you already installed the 2019.1.2 update? It is required, the ABOUT command will confirm if you have it or not.
Yes, I have already installed the 2019.1.2 update, anyway with the about command I do not see if it is or not but I remember installing it, I use the Autodesk desktop application and in AutoCAD it appears that I have no updates available!
