Hello, I've troubles with a particular dwg file.
I can work properly with the file, but when I try to print (dwg to pdf, but I also tried other printers) Autocad crashes and appears the Windows message
"AutoCAD Application has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
I tried more than one pc, and this happens both in Windows 7 and Windows 10, both in Autocad 2018 and in Autocad 2019.
I tried to change ctb file, I tried to select everything, copy and paste in an empty dwg, but there's always the same problem.
The others drawings of project, with almost the same setting, are ok, so I know there's something wrong with *this* file, but I can't understand what it is.
Thank a lot if you can help.
Solved by cadffm. Go to Solution.
Sebastian
I don't really understand where I made a mistake, but your solution worked so well,
thank you so much.
I followed the directions and I'm still getting the error code when I try to print or publish. Is there another work around? Is there a way to fix my file?
Thanks for the help!
