I just bought abobe version and I want to set up the screen as my 2008 version (See attached Screen shot)
Can any one suggest a good book to learn about how to set up 2018 as I have done for 2008?
I tried with help but did not work.
Any help will be appreciated.
Thanks.
Solved by Patchy. Go to Solution.
Thank you for the information. It is difficult to understand the tutor but, I will try to follow the instruction.
Thanks again.
I was able follow video and set up every thing excet to add a button for paper space. Another item is xref pictures. Under the insert I did not see any option for image xref.
