Happy New Year!
The vast majority of CAD users draw and design their work at full scale (1:1). The presentation or publication of drawings is where scaling comes into play.
Example: A house plan is drawn at actual size and there may be multiple floors, along with elevations and other project details, represented at different positions in the Model Space environment. Fixtures and other construction blocks are also full scale. We only need to scale these views for the purpose of providing working drawings with borders, title blocks, and other published content.
We typically add test and dimensions (annotate) after the majority of design work has come together. Of course alterations and revisions are sure to come but the annotation phase is usually a subsequent step to design.
I hope that I am interpreting your post correctly that you are trying to design at scale? I also looked at older posts you have made where you sought a scaled .dwt template file and it seems like you are still after this concept.
If you truly wish to have your actual designs scaled then you could consider drawing everything full size then using the SCALE command (no relation to print/plot scale) to reduce or increase the size of your design.
I welcome the opportunity to discuss further to see what you are really after and help you get there.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
