Autocad 2018 - New Layouts Tab - 2D Layouts from 3D Model
Message 1 of 9
I have created a 3D model, I have used the new Layout tab to create my 2D views in Paperspace.
In one of the views I want to freeze an object to omit this from this view but I cannot figure out how to do this since the layers for the 2D views are now MD_Visible etc. so freezing the object layer in a viewport won't work.
If you freeze the objects layer in the model it is omitted from every viewport.
Does anyone know if this can be done?
Replies (8)
Message 2 of 9
ennujozlagam
if i understand you correctly? when you are in paper space > go the model space of your viewport > go to your layer properties > look for VP freeze. thanks
Message 3 of 9
No sorry that's not what I was asking.
I am using the New Layout Viewports that were introduced in Autocad 2018.
These Automatically create views in paper space from a 3D model.
I want to freeze a layer in one of these automatic views.
Message 4 of 9
ennujozlagam
Are you referring to that (see attached) if yes you can only rename, delete, move/copy and add but you can't freeze. thanks
or post some screenshot?
Message 5 of 9
Sorry No its is this Viewport Layouts.
Message 6 of 9
ennujozlagam
yes that is my first suggestion, just go inside your viewport paperspace > (modelspace) then go to layer properties > then go to New VP Freeze column.thanks
you can't delete the object it will begone in your modelspace you can freeze in any viewport.
Message 7 of 9
ennujozlagam
are you referring to this? thanks
Message 8 of 9
mmmm Yes and No Smiley Happy
That will work for a 2D drawing but when you create views from a 3D model the layers created for the views are:
MD_Annotation
MD_ Hatching
MD_Hidden
MD_Visible
it does not create the layers that I have created in the model.
Message 9 of 9
ennujozlagam
maybe this one can help. refer to this LINK. thanks
