AutoCad 2018 execute tool not allowing Non-uniform scaling
Message 1 of 26
We are finally getting our employees to move away from their AutoCAD 2017 to AutoCAD 2018.  Now we are finding the tool palettes that allowed Non-Uniform scaling in AutoCAD 2017 does not allow it in AutoCAD 2018.
Seems that the Execute tool is not allowing it.
Is there a patch file needed for this?  I have checked to make sure our CADs are fully patched but still all machines are having the same issue.
Just wondering,
Ken
Replies (25)
Message 2 of 26
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 I am not sure that there are changes to the palettes between the two releases.  Are you trying to use the palettes that you created in AutoCAD 2017 and then just moved to the 2018 product?
Can you give me some more details /examples of what you are trying to do? I am happy to take a look at this issue for you.
What do you mean by the "Execute" tool?
John Vellek
Message 3 of 26
Thanks for the response.
I recently joined this company and they have custom palettes they have been using for quite some time. These palettes bring in all types of blocks for each discipline. The blocks are made without the uniform scaling so they do scale non-uniformly with the insert command in 2018.
However in 2018 we get the following with trying to scale when using the tool palettes"
[cid:[email protected]]
In 2017 our prompt looks like the following:
Both use the same tool palette and inserting the same block.
Ken
Message 4 of 26
Patchy
The command is the same and it can't find the blocks because you have not added that folder in the OPTIONS.
Look in the Support File Search Path.
Message 5 of 26
pendean
Community Legend
Community Legend
You have to come to the website to post pictures and share files: your email reply here shows nothing but a bunch of words and digits.
Message 6 of 26
Sorry about that. I attached the screen shot from 2017 and 2018. The block does insert just does not allow non-uniform scaling. Ken
Message 7 of 26
Patchy
What happen after you use insertion point? doesn't it pop up xyz?
Message 8 of 26
No it just places it in the model space. Once in the model space you can scale it non-uniformly with the scale command, just won't prompt when picking from the tool palette.
Ken
Message 9 of 26
Patchy
Have you tried just the command :
.insert
(put a period in front is insert)
Message 10 of 26
With that command the scale uniform is checked.  Is there a system setting to change that to be unchecked?
Ken
Message 11 of 26
john.vellek
Hi @Anonymous,
What options are available for this block insertion when you rt-click on the block in the tool palette?
Can you share a screen capture?
John Vellek
Message 12 of 26
pendean
Community Legend
Community Legend
Post screenshots from 2017 and 2018's TPs, right click on the same exact tool in both, select PROPERTIES, post that pop-up screenshot.
The commandline is simply responding to commands, it's no indication of what got called.
Message 13 of 26
Attached are Screen shots from 2017 and 2018 per your request.
Thanks again,
Ken
2017201720182018
john.vellek has embedded your image(s) for clarity
Message 14 of 26
john.vellek
Hi @Anonymous,
Can you share a couple of the blocks that are behaving in this manner?  I don't recall ever being able to set this in prior versions.
John Vellek
Message 15 of 26
Yes I have attached 2 files.
Don't laugh at the naming Im still trying to figure this one out. LOL
Message 16 of 26
john.vellek
Hi @Anonymous,
Nothing dumb about the file names but I am feeling dumb. Can you make a Screencast in 2018 that shows how you are used to seeing this work?
John Vellek
Message 17 of 26
Attached are the screen shots from both.
I click on the button on the tool palette in 2017 and in 2018 but get different prompts.
Message 18 of 26
I have a CAD savvy employee here running 2019 and he says it doesn't prompt for the x and y scaling, then he tried 2018 and it didn't prompt for x and y scaling but then tried 2017 then it prompted for the x and y scaling.
Sounds like something changed.
Message 19 of 26
pendean
Community Legend
Community Legend
Looks like TP in 2018-2019 is acting like INSERT command (pop-up version) and skipping over the scales questions, since the TP properties pre-defines a scale to 1 and no option for prompting at the commandline.
I like the 1x1 block idea in general though: has its limitations.
Message 20 of 26
YEAH - I decided to make a test palette with a test block and there isn't a prompt for scaling again. Something programing wise must have changed.
So I'm thinking we are going to have to create dynamic blocks for those items.
Thanks for looking into this for me, if there is any resolution please let me know.
Thanks again,
Ken
