I have an issue with the precision of my cursor.
When i try to move a point of a polyline, using "intersection" of the object snap settings, to match another object or polyline, the cursor is very "loose" and offers an intersection next to the polyline, not exactly on it, a little bit before or after it.
When i try to match other geometricals points of a polyline, like the middle or the corner (the one symbolised by triangle and square when you pass the cursor over it), it is accurate and match the exact point aimed for.
Snap is off, SCU is clean, all objects have Z on zero, ...
Any idea how to fix that ?
I like to be precise when i draw, so this is getting me crazy !
I see that hardware acceleration (HA) is enabled. As a test, have you checked this with HA disabled? Have you verified that the driver you're using is on the recommended list?
Thank you for your quick answer !
Yes, i tried with hardware acceleration on and off, but it doesn't change anything. And my driver is in the recommended list.
The problem just poped one day, i didn't have it before.
Here is a screencast. You can see that when i aim with the extension setting, it's not precise. But when i aim for a mark like the corner of the other polyline, it works fine.
Also, the problem seems to be quite inconstant, sometimes it does its job of intersection perfectly, and suddenly it seems "tired" and stops being precise.
Post that portion of your drawing, about the only way to trouble shoot something like that quickly.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Here's an extract of the drawing, in case anyone can help.
You are working a long way from 0,0. Any reason you can't move everything closer to the 0,0 origin point? Anomalies do start to show up when working that far away from 0,0.
GrantsPirate
