AutoCAD 2018 crash when using Dim Linear Fatal Error Code 0x00f8 ba21619ah
jdlandry504
jdlandry504
Has anyone run into AutoCAD 2018 crashing when using dim linear in a drawing.  The error that pops up is "FATAL ERROR: Unhandled Access Violation Reading 0x00f8 Exception at ba21619ah"  It has caused AutoCAD to crash 4 times today.  Up until today, it has been working fine.
Jason Landry
SM BIM-VDC Specialist
Bernhard
john.vellek
Hi @jdlandry504,
I have not seen any issues like this. Is this crash happening in only select drawings?  Try running AUDIT and PURGE and -PU>Regapps to see if you can remove any coruption and bloat. Are these drawings in a 2018 format?
If you would like to share one where this happens i would like to see if I can duplicate the issue.
John Vellek
jdlandry504
So it was an issue with the drawing itself.  audit and regapps did not work either.  it had to be exploded and then played into a new drawing.  Unfortunately i cannot share the drawing to to the project contract terms.
Jason Landry
Bernhard
