AutoCAD 2018.1.1: Unreadable Image
adri_groeneveld
Message 1 of 11
adri_groeneveld
I have a drawing with a raster Image reference containing a QR Code.
This example represents a geographic location.
http://chart.googleapis.com/chart?cht=qr&chs=500x500&chl=geo%3A53%2E3664860471372%2C6%2E376538258983...
This works fine until AutoCAD 18.1.1. The status of the ImageReference is Unreadable.
Can anyone tell me if this is a bug or policy?
Replies (10)
Message 2 of 11
HI
Ensure SHOW IMAGE and BACKGROUND TRANSPARENCY  Option is on condition
Ensure layer of Image is turned on.
Message 3 of 11
adri_groeneveld
Not in 2018.1.1
Message 4 of 11
HI
Ensure Source file's image is in Model view.
If problem persists, Pls share DWG files.
Message 5 of 11
john.vellek
Hi @adri_groeneveld,
Perhaps I am not understanding the issue. I downloaded the PNG file from the URL you provided. I open my AutoCAD 2018.1 and use IMAGEATTACH to insert the image into my drawing. It displays fine and in the XREF Manger I can also see the path.  Is this working on your computer in the same fashion? If not, can you attach your drawing file so I can take a look?
John Vellek
Message 6 of 11
john.vellek
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 7 of 11
adri_groeneveld
Hi John,
The source of the Raster image reference is not physical on disk but refering to google charts API.
This xref was created with the AutoCAD plugin of the month  QR-Codes for Autocad of December 2010.
In the first release of AutoCAD 2018 this was no issue.
I am working with Autocad 2018.1.1 on Windows 7 Enterprise SP1.
Message 8 of 11
john.vellek
HI @adri_groeneveld,
The plugin I see as the most current in the Autodesk App Store is ver 1.2 and indicates that it is compatible with AutoCAD versions 2013-2015.  Which version are you running?
I did try an Imageattach in 2018.1 and provided a URL for the path. This does seem to fail and I will bring it to the attention of the team.
John Vellek
Message 9 of 11
pendean
Community Legend
Community Legend
old plug-ins features/content in older AutOCAD versions are not guaranteed to work in newer AutoCAD versions unless the author of the plug-in provides such a guarantee: sorry, you will need to find the source image or create a new one.
Be careful how and when to use plug-ins: they are not a panacea all the time
Message 10 of 11
artc2
Try setting SECURELOAD to 0. In 2018.1 the GetRemoteFile functionality was changed to be controlled by SECURELOAD
Message 11 of 11
adri_groeneveld
Thank you for the solution.
I only do not understand why that security. It works more against you than the advantage.
