Announcements
AutoCAD 2017 - Wipeout in Model Space Covering Objects in Paper Space
mwalters
Observer
mwalters
Observer
Observer
We are having this issue with AutoCAD 2017 and AutoCAD LT 2016.
When creating a Wipeout in Model Space it is covering objects in Paper Space. (Simple example: We put a large wipeout behind text in model and then a Leader was drawn in paper space and it was covered by the wipeout in model space.)
Draw Order has been tried on the view port in paper space with no luck.
Verified that we were not drawing in the viewport.
Shutdown AutoCAD and restarted.
Does not print correctly (already tried Print paper space last)
This is happening on bases we created and bases that were sent to us. (Unrelated bases for different products.) This is happening on different versions of the software as well, but has only been happening for the last week. Three different Drafters on three different computers have tried to resolve this issue with no luck.
If anyone has suggestions I would be grateful.
Thank you for any advice in advance.
Mary
[ The subject line of this post has been edited for clarity by @handjonathan Original: Wipeout in Model Space Covering Objects in Paper Space ]
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Which plotter driver did you try? Have you tried multiple/different plotters, e.g. "DWG to PDF.pc3"?
This would have been my favorite suggestion, but if it was already tested and did not solve the issue, can you upload the drawing?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
put wipeoutframe on 2 may be it will work
deke01
In plotter control dialog box, is the "Plot Paperspace Last" radio button selected?
dehtoon
Community Visitor
Community Visitor
thanks, it is happening. sometime can't notice that.
handjonathan
Hi @mwalters
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Alfred.NESWADBA @Anonymous @deke01  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
