AutoCAD - Displayed color of ByBlock objects
kostial.mk
kostial.mk
Hello all,
is there a way to change the displayed color of objects, that have color set to ByBlock.
The thing is, that when I edit blocks, the object with ByBlock color are displayed as black. In these block there are also objects that have to be colored black and therefore I cannot instantly distinguish, which objects are set ByBlock and which are Black (or ByLayer).
It would help me, if the ByBlock color was displayed in different color (in my case for example yellow), not as black.
Is there a way to change the displayed color of ByBlock color?
Thank you in advance!
[ The subject line of this post has been edited for clarity by @handjonathan Original: Displayed color of ByBlock objects ]
Edwin.Rense
I think it would depend on what color black you use.
If you use color 7 (black/white) and color 250 (black) changing the background color should display both colors differently. (just not with 'white' background).
Maybe changing the block layers/colors would do the trick.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
illusionistNUGXG
Hmmm...usually the colour settings can be found under:
Options, 'display'-tab, 'colours'-button,
choose 'blockeditor' in the context field.
The different elements are there to select and assign the colour you want...
But i couldn't find a setting for the 'ByLayer' objects. I guess it is always black/white (dependant of the background colour) by default.
