Are there different versions of AutoCAD 2017? I was working with a version that had "Create View, Modify View, Update, Styles and Standards" panels on the Ribbon in both 3D Modeling and Drafting & Annotation workspaces. Somehow, I lost all workspaces and had to "Reset Settings to Default". The "Default" version didn't have these panels on the workspaces (see attached PDF). I'm wondering if there was an enhanced version that was originally installed that got replaced with a standard version. Does the Standard "vanilla" AutoCAD have these features?
Solved by WarrenGeissler. Go to Solution.
is there are chance this is LT?
CADnoob
When you reset your settings you might have lost your Partial Customization Files. The one you need to load is called MODELDOC.CUIX You also might be missing others (such as EXPRESS, CUSTOM, APPMANAGER, etc.)
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Yes! Menuload> Browse> MODELDOC worked! Thanks! I'll inform my IT department!
