AutoCAD Forum
AutoCAD 2017 - MTEXT Ribbon Gets Big
33 REPLIES 33
Message 1 of 34
cadmgmt
53868 Views, 33 Replies
cadmgmt
I have borrowed this old post as it seems to still be an issue without a solution that I can find.
Help would be appreciated. See the attached file.
AutoCAD 2017 SP1
Sometimes when editing MText, my ribbon gets HUGE and takes up half the screen. I've fixed this before by closing and re-opening AutoCAD. And, of course, it doesn't always do it. It looks like it's stretching the ribbon to show all my text styles. Is there some setting that needs to be selected or is this a glitch?
Thanks in advance for your help!
[ The subject line of this post has been edited for clarity by @handjonathan Original: MTEXT Ribbon Gets Big ]
AutoCAD 2017 SP1
33 REPLIES 33
Message 21 of 34
dturner5VYFA
in reply to: dbroad
dturner5VYFA
When I checked this setting, "Collapse as Needed" was already selected.
I changed the setting, applied and then changed it back to Collapse as Needed. Then Apply the change.
Problem corrected
Problem corrected
Message 22 of 34
mackland
in reply to: dbroad
mackland
If you are using Civil 3D this is located in the map.cuix not the all.cuix
Message 23 of 34
SteveMazza4062
in reply to: mackland
SteveMazza4062
Depends on how you have the CUIs set up.  For me, CIVIL is the Main CUI and ACAD is the relevant Partial CUI where this setting can be changed.
I have been encountering this issue, seemingly at random, on two different computers, both running Civil 3D 2018.  Very annoying, but I am thankful that my fellow users posted the temporary fix here.
Message 24 of 34
dturner5VYFA
It does seem to return randomly. I wonder whether it is drawing specific.
Message 25 of 34
brett_cci
in reply to: cadmgmt
brett_cci
I experience this issue too on occasion with ACE 2020 - I believe it did it with earlier versions as well, but can't remember.  It was annoying since the only fix that worked for me every time was to close down all open drawings and restart ACE.  Recently, however, I found cycling through all (4) ribbon display modes by either left-clicking the "Minimize To" button (left arrow button of the two at the far right end of the ribbon tab) or double left-clicking in the empty space anywhere off to the right of the (2) arrow buttons returns the text editor ribbon back to normal.  You don't even have to exit out of the mtext editor first.  Don't get me wrong, it's still annoying, but it at least saves the time from having to close down all drawings and restart ACE.  Hopefully this will help others.
Message 26 of 34
in reply to: brett_cci
Thank you. I have tried that but unfortunately it does not work for me.
The only thing that does work is to close all the drawings and reopen them
which wastes valuable time.
So annoying that years down the line they still have not found a solution to
fix the problem.
fix the problem.
Message 27 of 34
Civil3D Users:
CUI > Ribbon > Tabs >Civil 3D Annotate > Annotate - Text > Resize Style > Collapse as needed
Civil3D Users:
Message 28 of 34
RobDraw
RobDraw
That has already been suggested.
Rob
Rob
Message 29 of 34
Thank you for your reply.
It is not the text I need to resize but the entire ribbon
Message 30 of 34
RobtRoma
RobtRoma
This worked in AutoCAD LT 2022 when I tried it.  Thanks to those that made the suggestion and posted the solution.
@Anonymous wrote:
I fixed this issue with your suggestion, however instead of choosing "Collapse as Needed" which was already selected, I chose "Collapse Last" and it seemed to put the ribbon back to normal.
Message 31 of 34
Thank you! Purging fixed the problem for me, with AutoCAD 2018
Message 32 of 34
pg.caron
pg.caron
Community Visitor
Community Visitor
The purge did the trick for me.
Message 33 of 34
john.starrKZRKV
john.starrKZRKV
Is there a solution for AutoCAD Electrical? I have the same problem, but the CUI is a little different.
Version ACADE 2021
Version ACADE 2021
Message 34 of 34
TheClevelander
TheClevelander
Thank you Thank you Thank you. Nothing is more frustrating than when the official Autodesk Support Solution does not apply to the version of CAD that you are having the issue with. I was going crazy looking for 'Text Editor Contextual Tab' until I found you post.
AutoCAD Inside the Factory
