AutoCAD 2017 Memory Leak?
Message 1 of 56
So I was drafting away all day as I normally do... Later on in the day I noticed a lag when moving, drawing, trimming etc. So I check my RAM usage and it seemed quite high for the programs I had open. Open Task Manager and noticed acad.exe using over 2.5GB of RAM! So I save and close and reopen the same file (after closing all other programs). Now it's only using about 300MB of RAM. Simply zooming out 1 click and in 1 click repeatedly I can see the RAM usage start to grow but not drop at all. Within minutes its over 500MB by just zooming in and out.
If I open the same file in AutoCAD 2016 the RAM usage stays around 330MB no matter how much I zoom in and out.
System Info:
Windows 7 Home Premium
16GB RAM
250GB SSD
Intel i7 4790k CPU
Nvidia GTX 770
Replies (55)
Message 21 of 56
its not funny and this is call "complaining" for the products that we've purchased not "blaming" SIR.
Message 22 of 56
@RobDraw wrote:
It's funny how quickly people are to blame stuff out of their control when problems arise. It seems like some people are having graphics and/or system related trouble with 2017 but doesn't that happen with every release? The vast majority are not having problems. That is why people should make sure there are not other contributing factors before playing the blame game.
So rather than contributing to the conversation or offer another solution, you chose to complain about the people complaining?...
"...doesn't that happen with every release?"
No, never. 2014 ACAD worked fine... 2015 worked fine. 2016 worked fine. 2017 consumes RAM faster than all previous versions combined. And that's RAM, not DRAM, meaning it has nothing to do with my graphics hardware. If it's my system that's the problem then why haven't I had a single issue with any previous versions?
I'm not saying that there couldn't be some sort of compatibility issue with the many different hardware and software components that make up a system. But that's not my job to test. We pay Autodesk huge amounts of money for this software with the expectation that it will work better each time it is "improved". And since I have not changed anything on my end, am I out of line to think that the newest version of the same program, that i've been running for years without issue, is causing the problem?
Message 23 of 56
yeah?
Message 24 of 56
doesn't want to stop climbing
Message 25 of 56
pendean
Community Legend
Community Legend
Somehow you're not seeing SKETCHUP growing exponentially along with AutoCAD in your two screenshots 🙂
You've got something else going on.
Message 26 of 56
I have to agree that it seems you have something else eating RAM (and other system resources)- AutoCAD is using less than 2G in your taskmanager screenshots, yet you are over 70% total physical memory usage- somewhere approaching 12G on your 16G system. Try clicking the "Show processes from all users" button at the bottom left of taskmanager window, then sort again by RAM usage, and see what else pops up near the top. I also note 121 process running, even with your (very capable) processor you may want to look at disabling things you don't need, or at least preventing autostart on things that you don't use often/daily. I have had AutoCAD 2017 use in the range of 5 to 6G on a (notebook) system with 16G total RAM without serious slowdown, but I have that system "leaned-out" so that there are seldom more than 65~70 running processes, and rarely more than 50~60% total physical memory in use. (i5 3230M, 16G RAM, and GT730 GPU, if it matters) Judging by your processor, I would guess that you have available dimm-slots in your motherboard, good rule of thumb is to fill them all, since open slots leave memory channels not being used by the processor.
Message 27 of 56
RobDraw .. If this issue was happening to you, I am sure you would have tried all the recommended options first, only to hear AutoDesk run thru the same steps and then some while NEVER looking at their own software.  MANY MANY MANY times AutoDesk has ignored problems in their over-priced minimal update software and blamed the customer, and months later they quietly publish a solution that we have to seek out and find.
The solution with AutoDesk is almost always to just forget about bothering them (it's not their fault) and just go back to the last working version for the year or so it takes them to debug their software.
Edited by
Discussion_Admin
Message 28 of 56
If you have to take all these steps to "clear the RAM" ... somebody has made things too darn hard. NOBODY should ever have to do such stupidly complicated things to run software. It sounds more like somebody named Autodesk needs to code better software.
Message 29 of 56
Not saying this is technically incorrect ... but that is THE MOST RIDICULOUS THING I have heard this year. If anyone has to take these steps ... "somebody" is doing something wrong and it's not the end user.
Message 30 of 56
Oh great. Another Autodesk problem forum with NO SOLUTION. Thanks for nothing.
Message 31 of 56
RobDraw
@Anonymous wrote:
RobDraw If this issue was happening to you, I am sure you would have tried all the recommended options first, only to hear AutoDesk run thru the same steps and then some while NEVER looking at their own software.  MANY MANY MANY times AutoDesk has ignored problems in their over-priced minimal update software and blamed the customer, and months later they quietly publish a solution that we have to seek out and find.
From my experience, this type of problem is usually system related rather than at the program level. So, your assumptions about how I would handle it are wrong. Especially since I have never heard of anything similar to this related to the use of the program. Also, I have a pet peeve for AutoCAD.Desk bashers that refuse to believe that they (or their machine) might be doing something wrong.
Edited by
Discussion_Admin
Rob
Message 32 of 56
Having the same memory leak problem on all our computer in the firm.
I'm searching for days now what the problem could be.
Autocad 2016 and previous versions never had or having problems.
Did almost everything that i can find on the internet.
Every possible setting/ variable in autocad changed what could have had effect.
(everything with regen, visibility options, hardware acceleration, ...
Changed al sign ins
Shutted down antivirus, ect
Changed register
Changed drivers
All the things that worked the last 10 years don't work now
what i see:
I start (every) drawing and it works perfect.
After 15 min it's start to lag
After 1 hour i can't do anything with our computers (+20).
Autocad 2016 works perfect...
Message 33 of 56
Alfred.NESWADBA
Start command _GRAPHICSCONFIG in both, AutoCAD 2016 and 2017, create a screenshot and show us that screenshots please.
-  alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 34 of 56
Card name: NVIDIA Quadro K2000D
Driver version: 21.21.13.6926
Tuning Date: 14/10/2016
Virtual device: Dx11 (Hardware)
The card and driver meets the recommended requirement.
Display Adapters:
NVIDIA Quadro K2000D(Primary)
Certification:
Hardware Available True
Hardware Recommended False
Status 0
Hardware ID 2
Hardware Feature Level 50
Software Feature Level 50
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Additional System Information:
ComputerSystem
Manufacturer Gigabyte Technology Co., Ltd.
Model To be filled by O.E.M.
NumberOfProcessors 1
TotalPhysicalMemory 34272686080
Processor
MaxClockSpeed 3701
Name Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
NumberOfCores 4
NumberOfLogicalProcessors 8
Revision 15876
OperatingSystem
Name Microsoft Windows 8.1 Pro|C:\Windows|\Device\Harddisk0\Partition2
OSLanguage 1043
ServicePackMajorVersion 0
ServicePackMinorVersion 0
TotalSwapSpaceSize
TotalVirtualMemorySize 53949420
Version 6.3.9600
DiskDrive0
Model Generic- SM/xD-Picture USB Device
Name \\.\PHYSICALDRIVE3
Size
DiskDrive1
Model Generic- Compact Flash USB Device
Name \\.\PHYSICALDRIVE2
Size
DiskDrive2
Model Samsung SSD 840 EVO 250GB
Name \\.\PHYSICALDRIVE0
Size 250056737280
DiskDrive3
Model Generic- SD/MMC USB Device
Name \\.\PHYSICALDRIVE1
Size
DiskDrive4
Model Generic- MS/MS-Pro USB Device
Name \\.\PHYSICALDRIVE4
Size
DesktopMonitor
MonitorManufacturer (Standaardbeeldschermtypen)
MonitorType Algemeen PnP-beeldscherm
Name Algemeen PnP-beeldscherm
ScreenHeight
ScreenWidth
DisplayConfiguration
DeviceName NVIDIA Quadro K2000D
DisplayFrequency 60
DriverVersion
PelsHeight 768
PelsWidth 1024
VideoController
AdapterDACType Integrated RAMDAC
AdapterRAM 2147483648
ConfigManagerErrorCode 0
CurrentHorizontalResolution 1920
CurrentVerticalResolution 1200
DriverDate 20160830000000.000000-000
DriverVersion 21.21.13.6926
InstalledDisplayDrivers nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Status OK
TimeOfLastReset
VideoArchitecture 5
VideoModeDescription 1920 x 1200 x 4294967296 kleuren
PageFile
FileName pagefile
FileSize 20971520000
Process Information:
Loaded ARX and CRX Modules
acapp.arx
acapp.crx
acautoloader.crx
acautoloader.arx
acjscorestub.crx
acgsconfig.arx
acgsconfig.crx
accloudconnect.crx
acconnectwebservices.arx
acismui.arx
acismui.crx
aeccore.crx
acETransmitui.arx
aecloader.arx
acvmtools.crx
accmmgr.crx
acparameter.crx
vl.crx
AcGeoLocationUI.arx
AcAuthEnviron.arx
acgeolocationoe.crx
aclaunchnfw.arx
acsign.arx
acetutil.arx
vl.arx
acopm.arx
Acpi.arx
acobjclassimp.arx
AcOcSchemaUtil.arx
acopmext.arx
AcFdUi.arx
AcPEXCtl.arx
acexperience.arx
acpublish.crx
acpublish.arx
acdim.arx
acdim.crx
acseek.arx
acmted.crx
Effects:
ACAD_LineSmoothing supported turned off
ACAD_PerPixelLighting supported turned off
ACAD_AdvancedMaterial supported turned off
ACAD_FullShadows supported turned off
ACAD_TextureCompression supported turned on
ACAD_HQGeom supported turned off
ACAD_GlowHighlighting supported turned on
ACAD_Dx11 supported turned on
2016:
Tuning Date: 4/10/2016
Display Adapters:
Certification:
Status 0
Hardware ID 2
General Options:
Discard Backfaces False
Handedness Right
Maximum LODs 6
ComputerSystem
Processor
MaxClockSpeed 3701
NumberOfCores 4
Revision 15876
OperatingSystem
OSLanguage 1043
TotalSwapSpaceSize
Version 6.3.9600
DiskDrive0
Size
DiskDrive1
Size
DiskDrive2
Size 250056737280
DiskDrive3
Size
DiskDrive4
Size
DesktopMonitor
ScreenHeight
ScreenWidth
DisplayFrequency 60
DriverVersion
PelsHeight 768
PelsWidth 1024
VideoController
Status OK
TimeOfLastReset
VideoArchitecture 5
PageFile
FileName pagefile
acapp.arx
acapp.crx
acautoloader.crx
acautoloader.arx
acjscorestub.crx
acgsconfig.arx
acgsconfig.crx
acvmtools.crx
vl.crx
aclaunchnfw.arx
appload.arx
acsign.arx
AxUi.arx
AecGuiBase.arx
AecCore.crx
AcFdUi.arx
AecApp.arx
AecUIStatusBar.arx
acblock.crx
acismui.arx
acismui.crx
acETransmitui.arx
aecloader.arx
acpointcloud.crx
acdbpointcloud.arx
acauthenviron.arx
acparameter.crx
acsceneui.arx
AcCamera.arx
acsceneui.crx
aeccsubentsel.arx
acmapgwsetransmit.crx
acstetransmit.crx
acblock.arx
aecutilities.arx
AecProject.arx
acpublish.crx
aeclayermanagerui.arx
Acopm.arx
Acpi.arx
acobjclassimp.arx
AcOcSchemaUtil.arx
acopmext.arx
AcPEXCtl.arx
accloudconnect.crx
acetutil.arx
acmaploader.arx
AcMapCmdTarget.arx
acadmap.arx
AcMapAde.arx
AcMapAnnotUi.arx
acmapird.arx
ase.arx
acmapobjclassui.arx
AcMapObjClassPwApi.arx
acmapworkspace.arx
AcMapDisplayManagement.arx
AcMapObjClassApi.arx
AcMapFeatureSourceManager.arx
AcMapMapBook.arx
AcGiMapToHeidi.arx
AcMapRastUtils71.arx
AcMapPropMan.arx
AcSmPublishUtils.arx
AcFdEval.crx
AcSmDwgMine.arx
accalcengine.crx
acpublish.arx
aecpublish.arx
aceplotx.crx
acmaprightclickmenu.arx
acmapfeatureentitytooltips.arx
acmapdmtask.arx
AcMapFeatureEntityUI.arx
AcTcTools.arx
AcTp.arx
acmapmapbookui.arx
acmapstatusbar.arx
acmapdwfapi.arx
acmaprastex71.arx
aeccdgn3dplinestyle.crx
AeccCoreBase.crx
aeccuimodel.arx
AeccUiBase.arx
AeccUiLand.arx
AeccUiTce.arx
AeccPlanProdSvc.crx
aecceventviewer.arx
aeccuiqto.arx
AeccPublishSvc.crx
aeccuinetwork.arx
aeccuipressurepipes.arx
aeccuiroadway.arx
aeccuisurvey.arx
aeccuiplanprod.arx
aeccpublish.arx
aeccuihydrology.arx
aeccuimapcheck.arx
aeccuibuildingsite.arx
aeccuipointcloud.arx
aeccuimgr.arx
aeccuistyleman.arx
aeccuicfdb.arx
aeccuidataexchange.arx
aeccuiaiwinterop.arx
AeccImxImpExpSvc.crx
c3d_raillib.arx
c3d_railxlib.arx
vl.arx
AeccISDBatchConverter.arx
acexperience.arx
acdim.arx
acdim.crx
acoscale.arx
Effects:
ACAD_LineSmoothing not supported turned on
ACAD_PerPixelLighting supported turned on
ACAD_FullShadows supported turned on
ACAD_TextureCompression supported turned off
ACAD_HQGeom supported turned on
Message 35 of 56
Little update.
The way autocad 2017 connects to the autodesk accounts is not the same as autocad 2016.
We have a proxy and that is blocking the 2017 connection.
IT WORKS WITH 2016...
It's possible the failing connection is the cause of the "memory leak " symptom.
Not for sure yet ...
Keep testing it ...
Message 36 of 56
braudpat
Hello
I can confirm that ACAD 2017 is using more memory !
Compared to 2016/2015 !
2014 was better and 2012 was much better !!
Of course I have done tests on HUGE 2D DWGs (more than 300 Mb) !
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 37 of 56
Mike_NZ
I am having exactly the same issue and it is really screwing with my productivity.
I am running Civil 3d 2017. When i first open the drawings the ram usage is fine, but it slowly creeps up and i am regularly seeing over 3 gig ram usage from the same drawings over an hour or so. The most easy way to push the ram usage up is by regularly switching tabs with viewports. Not sure if this is a cacheing type error.
To give it a go just open a DWG with a few tabs containing viewports and just cycle through them.
The only way i can seem to resolve this is to Save, close and reopen. Always auditing an purging. I keep forgetting to regularly close and open and get increasingly frustrated.
I run nothing else, of note, on my system other than my autodesk software to maximise the chance of spotting where things are going wrong. This issue is definately an Autodesk issue.
Message 38 of 56
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
If the drawing has 3 layouts, and you open it, change from model to layout 1 ... how long does it need to switch the first time and then the second and third time?
Also does the memory raise when you change the first time from model to layout 1 ... or does the memory consumption raise with every change, also with the 10th change?
- alfred -
Alfred NESWADBA
Message 39 of 56
haven't found a solution.
thougt it could be a proxy problem ( couldn't connect to my account in autocad). Connection solved. Memory leak signs not ...
You are not the only one who see his productivity screwed up.
Message 40 of 56
for me: after opening new autocad and new drawing the actions are instant and memory stays at 318-320.000 kb after +20changes.
This wil soon not be possible anymore
W8.1
i7 4820K 3.7Ghz
32 Gb DDR 3
SSD drive
