Autocad 2017 Arabic Language when Save as PDF text changes
Hi guys.
I have this issue that when I try to save a drawing that contains Arabic language in it's text. the writing get missed up and not connected as it should and appear in the autocad as seen Below
I have tried looking for solution online from previous people who had the same issue but none of them worked.
Thanks in advance
pendean
Community Legend
Community Legend
Which PDF driver are you using? Most find 3rd party PDF river work best.
Also explore similar posts https://forums.autodesk.com/t5/autocad-forum/autocad-drawing-converted-to-pdf-arabic-text-getting-ch...
I have seen that post and tried it but not working.
I am using the default PDF plot in the Autocad. What are some of the 3rd party PDF driver that I can try if you have suggestions?
