Autocad 2016 - HATCH PROBLEM too low density
Hi to everyone!
I`m a littlebit desperate. I can't find a solution for my problem.
Suddenly I have problems with some of the hatches, for example GRAVEL and CONCRETE (and similar patterns like DOTS ect.) original autocad patterns.
I can't make a high density hatch, the concrete hatch even doesn't show or shows solid.
My HPMAXLINES value is 10.000.000 from the begining. And the hatch scale won't go UNDER 0.01.
Help me please!
Thank you!
imadHabash
would you draw rectangles and hatch it then attache it here as CAD file ?
Imad Habash
Here is the file, with patterns that are bothering me. I controlled some other patterns randomly and it seems that are working fine...
Alfred.NESWADBA
Take a look to the attached drawing, I changed the hatchscale from 0.01 to 0.002 ... works fine, can you see the hatches?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
imadHabash
to reach for proper scale try to use DDUNITS command to increase precision.
Imad Habash
I knew it was a stupid solution. I see the hatches an because my Hatch Pattern Scale was showing 0.00, I checked the units options which was set to 0.00 presicion. Change it to 0.000 and it's working!
Thank you!
Thank you! Just discovered!..
