AutoCAD Forum
AutoCAD 2015 with OS X El Capitan
2 REPLIES 2
525 Views, 2 Replies
IS someone going to fix the issue soon???
2 REPLIES 2
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
And which issue are you speaking about?
The only possible problem I see is that you are trying to work with AutoCAD on an operating system that is not supported (>>>look to system requirements<<<).
- alfred -
BTW: there is a special forum for AutoCAD on Mac there >>>click<<<.
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
pendean
if you read this before posting you'd be in a forum where the topic is discussed and solutions likely presented already http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/the-autocad-for-mac-forum-has-moved/td-p/4...
AutoCAD Inside the Factory
