@Cadologist, that's what I'm wondering too. I have access to 2015, but I find it runs much slower than my 2013 license so I'm loathe to switch to it. I also found that link you sent and couldn't hunt down the original plugin it linked to (the link is now dead).
Do you have access to your old machine? If so you could probably copy the files for it, or you may even have the downloaded installer still on the machine.
Good luck,
That should not be the case. Have you checked your search file paths and their order??
or ....
Are you running full time shaded views while modeling?? 2015 increased the resolution of shaded views somewhat and caused some slow-down of orbiting in shaded views, but generally my benchmark tests show a slight increase in performance in 2015.
@Anonymous it is incredibly slow. I don't work in 3D at all, so I doubt that is the problem. I've switched over to 2015 today since I can easily get my file tabs back that way, and it has been nothing but dragging and poking around. I'm not working in a particuarly complicated or large file either.
Check your system against the minimum system requirements published by Autodesk.
Make sure you have all updates and patches installed
Make sure your server is up to date
Make sure your ACAD search path is fully functional and in the right order.
Turn off (uninstall) any cloud/web/internet links and Autodesk A360 hoodoo.
Hi @Anonymous,
I am surprised that the AutoCAD 2015 is slower than your 2013. Is it possibly file specific? Can you attach one of your typical files for me to examine?
Do you have any add-ins installed? Are you working on a network? Where are the files you are working on located?
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
