when i was trying to install autocad 2015 on windows 10 it shows this error however it dosent stop there and also get up to the page where i have choose the componenets i need to install and after that it stops with an error installation failed.
Is AutoCAD 2015 supported on Windows 10?
Have you searched for solutions to install on Windows 10?
AutoCAD 2015 installation on Windows 10 does not work, but in your case it looks like it does not stop at the "usual position", I'm wondering that you got it up to the materials library. Sounds interesting.
Could you first verify that the file exists?
In case of F: is a DVD driver can you copy the complete content to your local harddisk and try to start the installer from that copy?
At least: is it a DVD or have you downloaded the setup media, if downloaded it might help to redownload the package.
Good luck, - alfred -
yes it is supported i had also installed autocad 2015 but i was reinstalling to add autodesk 360 and recap to my pc then i got this error
>> yes it is supported
Where did you get that info from? Can you show us a link to that info?
Look to that article >>>click<<< which states (currently) no, it's not supported.
>> i am installing from iso file
Where did you get the ISO-file from? I would redownload it as I think the package might have issues when that file is missing ... BTW is it missing?
- alfred -
it is supported and i am using it but i was just reinstalling it to add atodesk 360 and recap to it
it's quite difficult to help if none of the questions are answered, so I'm out, sorry.
- alfred -
