AutoCAD 2015 freezes on opening older files. AutoCAD 2014 opens them just fine. This is an office wide occurance, please help!
As desinged? Why? So if we need to reference an old file, we have to go open a whole other application? That is stupid. In a few years are our older files just lost?
I was kidding about the as designed, that just seem to be autodesk standard answer when they don't want to admit 2015 is messed up
I gotcha. Hopefully someone has an answer, in another post months ago about a Revit 2015 problem, I was basically told to cross my fingers and hope that it is fixed for 2016. Good thing this stuff is cheap!
there are not xrefs affiliated with the file I am in. When I do a recoverall command, it gets hung up and says:
"illegal recursion in shape 54".
I have narrowed the problem down to a text style and shape, attached is a file with the text in it that crashes 2015, but opens fine in 2014.
Any ideas? Thanks!
Any ideas? Thanks!
not sure what you just said, but i have confirmed only the computers that have installed Service Pack 2 for 2015 have this problem. This is infuriating! We will not do any more upgrades or R2 for our projects. Autodesk needs to release stuff every other year and get things right!!!
this is also affecting our current projects, and screwing up fonts on current projects, see attached.
Again, only computers that have installed Service Pack 2 for 2015 have this problem.
Yes we have thought of uninstalling the service pack and it works, but typically we will want to install a service pack to "fix" the bugs that the new versions undoubtedly will bring us every year. It is just not a very warm and fuzzy feeling to know we may not have the service packs as help. If there is no other solution, I have to make sure 25 users have uninstalled the service pack.
Thanks for your help! I rarely submit a suport request straight to Autodesk anymore. With these forums, you get both Autodesk suport and other users to help out.
Autodesk will be looking at this at some point just like previous posts I have done on this forum, in fact, Saturday they sent an email inquiring about this issue. So Autodesk will see this, I promise.
So the file doesn't open in either version on your end. That is interesting, not sure why that is, it opens fine for us and our clients (without service pack 2 installed). I guess we will uninstall the service packs on our computers for now.
Thanks for trying
Thanks for trying
Autodesk is aware of this issue, and we are looking into possible solutions. There are two articles that may help to resolve this for you in the meantime. Please take a look at the links below:
http://knowledge.autodesk.com/article/Fatal-error-while-using-drawing-tabs-in-AutoCAD-2015
http://knowledge.autodesk.com/article/AutoCAD-2015-hangs-after-installing-Service-Pack-2
