AutoCAD 2015 Failed Installation and run.
Good morning,
I have a problem with AutoCad 2015.  I've tried to install it, but the installation has failed, for some DLLs missing. So i uninstalled it  and i have tried reinstalled it, but the installer tells me that it is already installed in my PC! I have also deleted the installations files, deletes the voices in the system registry but there wasn't nothing to do. If i try to install it the results is that i have already done it and it is ready to be used, but it isn't true!
Thank you for your help!
Thank you for your help.
