AutoCad 2015 crashes while loading
thedraftingboard
thedraftingboard
Help!
I have an AutoCad 2015 stand alone license.  It has started crashing while loading, and I can not longer operate it.  Does anyone have any ideas on how to fix this problem?
Thanks Sarah
Accepted solutions (3)
BeKirra
Similar to my reply to other thread, I suggest you to check the system requirements. Please see the link below:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/System-r...
Then check if your AutoCAD is up-to-date.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
vinodkl
Try Resetting the AutoCAD, may be that would fix the issue. To reset your AutoCAD click on start button and click on all programs and then select Autodesk and again select AutoCAD 2015 and click on "Reset setting to default" as shown in below snapshot.default.JPG
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
i suggest also to check from control panel the windows update . especially microsoft c++ redistributable .
Imad Habash
thedraftingboard
Thanks for the help everyone, I had had problems in the past with crashing and I turned off hardware acceleration (which fixed my problem). I ran troubleshooting on Autocad externally and I was able to turn off hardware acceleration (again) which has gotten my Autocad working again.  It looks like an update of my graphics card is in order to fix this problem?
Thanks again Sarah
