AutoCAD Forum
autocad 2014 wf beam library
5 REPLIES 5
4102 Views, 5 Replies
Where is the wide flange beam library located at that shows beams in section
5 REPLIES 5
imadHabash
Hi and Welcome to AutoDesk Forum,
if do you mean the attached image press Ctrl+3.if else kindly provide us with more details.
Imad Habash
in reply to: imadHabash
The one i am looking for has a list of wide flange beams (e.g. w8X10, w10X33, w6X15, w12X26 etc.) The tool pallet show's what i need but i can't figure out how to get the right size beam i need. It only pop's up the same size. Thank's
imadHabash
If i understand you just click the dynamic block (WF beam) after insert it of course.then click the blue arrow to get a lot of sizes.
is that what you ask for?
Imad Habash
Got it. Thank's
Can you get additional beam sizes, as well, cross sections of angles.
AutoCAD Inside the Factory
