AutoCad 2014 unable to load survey, terrain, parcel menus and others
Hello I am new using the 3D autocad, I have installed on my w8.1 PC, but I am unable to load the menu I use commonly for my land survey jobs..
My question is: Does Autocad 2014 load those menus? How I do load them.? Where are de Cui files? I am lost...
Alfred.NESWADBA
Have you done your own menus? Or did you get the menus from an application you installed (if so you have to install the application to get the menus).
If you tried to load your menus:
  • What message do you get when you try to load the menu?
  • What command do you use to load the menu?
Sorry that I don't understand your post completly, but when you have a menu for land-surveying functions, how should we know where you have stored these menus?
Maybe you can explain more detailed what you had previously, hopefully we have then a chance to help.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hi Alfred,, thanks for supporting me..
My concern is that the Autocad 2014 is not the same that Autocad C3D.. is that right.? It seems the Survey and Terrain menu dont load...
So as I have a trial..so I did was download the trial for AutoCAD C3D..
Hope to see if that works for me..
Thanks..
