I have two files that have become stuck zoomed all the way in or out with no way to return to a normal view. The message "Already zoomed out as far as possible" is displayed over the coordinates while attempting to zoom, and zooming in even a little results in "Already zoomed in as far as possible". The coordinates displayed are ridiculously high like "4.474E+19, 1.411E+19". When making a selection window over the entire drawing area, it selects what I assume is the entire drawing, displayed as a little bundle of grips, and a small crosshair at the top right. Upon hitting Esc at this point, the drawing is visible as a single pixel. Zooming in on this pixel has no effect, and even when "zoomed in as far as possible," it still displays as one pixel.
I was going to include that Previewing resulted in a single pixel as well, but I just tried it again and it appears normal on both files. This would be fine but there are still changes I need to make to the layouts.
When I open a different file and zoom out, it stops at the expected distance and doing Zoom Extents returns the page to the center.
Model space acts as normal.
Things I have tried so far:
Zoom extents, zoom all, etc.
Regen, regenall, etc.
Closing and reopening AutoCAD.
Is there anyway to fix this without redoing everything in a new file?
Solved by pendean. Go to Solution.
Welcome to these Forums!
Can you post the drawing file(s) it(them)self(ves)?
