Hi at all!
I am trying to install a student version (should be no difference to the normal version) of AutoCAD 2014.
When I installed it for the first time, everything seemed to be ok. The installation itself went well, no information about a failure, but when I tried to start AutoCAD 2014 i got the following error: FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at e4510004h
A friend of mine then gave me the advice to reinstall my .NET framework versions. So did I. After launching AutoCAD again, I got nearly the same failure, the number at the end changed to f9230004h.
I hope that the failure is called "fatal error" because I am installing a german version, but I think so.
If anyone could help, I would appreciate that.
what operating system do you have? What graphic card do you have?
Have you installed the service pack too?
Have you tried to start AutoCAD with right-click onto the icon ==> "start as administrator"?
- alfred -
Hi, thanks for the quick answer!
Windows 7, 64 bit
NVIDIA GeForce GTX 660M
Which service pack do you mean? For Win 7 I have SP1 installed, SP1 also for the NET framework (so the actual version is 4.5.1)
I am the administrator.. But I just tried to start AutoCAD as you said, same problem!
AutoCAD 2014 service pack 1
So you can create a new user-account (with full local permissions), login with that account and try to start AutoCAD there?
At least, if not necessary, you might uninstall Framework 4.5x and install 4.0 (as that is the Framework that is installed with AutoCAD)
- alfred -
It seems that I found a solution for my problem!
I am using a Lenovo IdeaPad Y580, there I have the OneKey functions, namely OneKey Recovery and OneKey Theater.
Here I read about shutting this functions down in the task manager, although the failure code was different, and so I tried this. And it worked 😉
Thanks for your fast help though!
EDIT: Can you or anybody tell me, why I have to do this before working with AutoCAD 2014?
thank you for your feedback, good to know you got it solved.
And that's the perfect proof why system-information is so important! The word "Lenovo" would have raised my remembering to the same (or similar) thread you already found 😉
- alfred -
Just guessing: it loads libraries into the memory that are not compatible with AutoCAD or it's installation procedure.
- alfred -
