AutoCAD 2014 drawing tabs and command line missing
jpedersen
jpedersen
Morning All,
The last three times I have started my ACAD 2014 the drawing tabs are gone. Any suggestions?
Also, my command line is missing and all I see when I hit my F2 is my previous entries except for the current entry. Any suggestions on this one?
Any help would be great!
Autodesk Plant 3D Design Suite Premium 2015
Navisworks Freedom-Sim-Manage 2015
Replies (40)
nrz13
Drawing tabs (file tabs) are controlled by entering FILETAB and FILETABCLOSE at the command line.
The command line is toggled on and off with the Ctrl+9 keyboard shortcut.
I"m not sure why they suddenly disappeared on you, but hopefully they'll stick around after getting them back on.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Charles_Shade
Welcome to the Autodesk Forums!
As mentioned above and save your WORKSPACE.
jpedersen
FILETAB worked - thank you.
CTRL + 9 did not work. . .
jpedersen
thank you.
I have my workspace settings set to always save changes.
CTRL + 9 did not work...
any other suggestions?
nrz13
The command line controls for the command line visibility are COMMANDLINE and COMMANDLINECLOSE.
nestly2
I would recommend manually saving your workspaces rather than saving them automatically because it's too easy to inadvertently save unwanted changes, as may have happened here.
Your command line may be off-screen.  If so, you should be able to restore it to it's original position in the CUI.  Select the workspace, then expand "Palettes" and select "Command Line" in the right panel, then edit it's properties in the lower right panel (Show = Yes / Orientation = Bottom)
Here's a demo -->  http://www.screencast.com/t/kvsIb70dSk
jpedersen
going into the CUI was the trick!
Thank you.
jpedersen
Thank you all for your help...its nice knowing you can ask for help and get this many replies back in less than a day! Hope I can help one of you out sometime.
Now get back to drawing some polylines!!
Filetab does not work for me
Ctl+9 works for me, but I think the command line is minimized and hidden.
When I pressed ctl+9 it says it is closing/opening it, however I can't find the command line.  Where could it be?
nrz13
It could be the transparency is set to 10% opacity or something like that, which means it is there, but just barely visible.  If that is the case, it should toggle to opaque when you move the mouse cursor over it.  Can you post a screenshot of your AutoCAD when the command line has been toggled on?
Also note that the default look for the command line in 2014 (and 2013, I think) is a floating toolbar-style object, not the full-width command line with white background of older versions.  If you're able to find the command line, you can dock it to the top or bottom of your AutoCAD window to get the old style back.
Dear Sir,
I using autocad 2014 trial version i drawed something with this version. when i saved and closed my works after that is saved and cloaed. when i working for opening my drawings again i can not find any my works or draws in the work space. but i am sure there is my drawins. foreample 1-) i can see my drawings as a draft/icon in the small window. when cursor came on the my drawings(Generator fuel system normaly selenoid valve fails to close.dwg) file like attached page-1 in pdf file 2-) when i draw sample frame or any line  with  line comment to the model and after i selecting that frame with CTR+A comment for see line properties there is showing 1965 quantity varies lines like page-2 at pdf file. but i i can not find them. i do not know how i loss them and can not finding. 3-) last when i clicking quick view layouts near of model like images page-3 at pdf file i can see as a draft my drawings but wen i double-clicked opening balk page and becoming gone drawings. tried much methods, properties of work space, view ports properties, zoom exteneds like thats. but i could not fixed. i attached images and my dwg file.  if anybody help i will be grateful.
King regards
nrz13
Bayramalieren:
I suggest you start your own thread for your issue, which is completely different from this thread you've posted in.
To attempt to answer your question, though, I would try using the Audit and Recover commands on the drawing to see if that fixes your problem.
Dear NRZ13
Thank you for your reccomendation i tried but i could not fixed. Do you have
another suggestion fort his issue?
Sayg?lar?mla / Respectfully,
Bayram Ali EREN
Mechanical Engineer
Mazar-e-Sharif /Afghanistan
+90 538 285 08 64
+93 785 850 817
http://www.metag.com.tr/
A??klama: A??klama: A??klama: A??klama: A??klama: A??klama: A??klama:
cid:image001.jpg@01CBC150.E2B37FB0
Esteemed nrz13,
Thank you for your helpsbut i tried your says, some smilar commands and others but i couldn't solve. Please if you can fix sample new attached my drawing fix after can you send to me again? because i can't. i saved at difeerent version(autocad 2010) and attached.
Kind regards
BAE
Patchy
Who made them invisible?
Esteemed sir,
I think i changed some options bu i do not know which are  i changed and now Atuocad automatically saving like that because i tried after that save like different version and as save-as but i could not see anything. can we get back or recover this drawings?
thanks a lot for your helps.
regards.
Patchy
This is all I can recover on your drawing.
Dear Patchy,
thank you very much for your helps and kinds.I have got recovered my drwings. Can you tell me how you fixed or how i broken them. we have a word about this" don't give fish teach fishing so i do not come for fish allways" because we can meet again same problem. thank you again for your understanding.
best regards.
B.A.E
