AutoCAD Forum
autocad 2014 and burst
8 REPLIES 8
Message 1 of 9
3907 Views, 8 Replies
In 2014 i have a specific problem with burst command .  other express tool commands work fine .
On launching the command i get an error message : about vlax objects
and command quits
8 REPLIES 8
Message 2 of 9
pendean
Post a screenshot of the actual error message please
Message 3 of 9
3wood
Please try attached EXPLODEALL.vlx.
Sometime BURST doesn't work properly.
Message 4 of 9
there is no alert
its only at the command line
error message says : "  incorrect argument: objets VLA: #<VLA-OBJECT 000000002ed23278>"
and command is not executed
Message 5 of 9
pendean
You may have a bad install of ET: did you by chance "migrate" when you started using or after installing R2014?
Message 6 of 9
in reply to: pendean
i did not migrate .
so far as its the only E T command that has a problem .
By the way the explodeall vlx also returns an error and quits .
error message is :
"activeX server found an error : load DLL library error "
Message 7 of 9
i forgot to mention i run windows 7 x64 , in case its relevant .
Message 8 of 9
pendean
I am too, BURST works fine, so does the freeware posted above.
Any chance you can reinstall ET?
Message 9 of 9
autocad reinstall did it . Burst command is working again. .
vlx issue persists , obviously due to something else .
AutoCAD Inside the Factory
