Is there a way to get a hold of AutoCad 2014 still? Will my 2018 license work with that version?
We have a very old plugin that I want to try and use on the old version.
Kevin
Kevin
Solved by natasha.l. Go to Solution.
I can't find a 2014 download anywhere, and if you did find one, I would guess it wouldn't activate. You could also find the plugin folder and see if you can edit the "PackageContents.xml" file to include the version you are running. It all depends on the plug-in and the source files it uses and\or included with it.
Look for the SeriesMin and SeriesMax values
<RuntimeRequirements SupportPath="./Contents" OS="Win32|Win64" Platform="AutoCAD*|AutoCAD" SeriesMin="R18.2" SeriesMax="R22.0" />
Places to look for plug-in:
C:\Program Files\Autodesk\ApplicationPlugins
C:\Program Files (x86)\Autodesk\ApplicationPlugins
C:\Users\%username%\AppData\Roaming\Autodesk\ApplicationPlugins
The 2014 version is retired by Autodesk and no longer available by download. Did you ever own 2014 in the past? If you did what was your upgrade path and that will determine if you can get a temporary link to download
Mark Lancaster
& Autodesk Services MarketPlace Provider
Mark Lancaster
Thanks for the ideas, but I know for a fact that this plugin will only work on 2014 as it uses a feature that no longer exists 2015+ (point cloud indexer). I'm trying to see if there are any common functionality between this version and newer versions that can do something similar.
Kevin
Kevin
Hello @kmiller6ZP7L,
It seems like you are looking for something like Autodesk Recap for AutoCAD & Revit. It allows you view & edit an indexed point cloud file into a project or convert a raw format point cloud file. Here are all the features it provides: Features of ReCap software
Thank you for posting.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Natasha
Helpful Links:
that me we cannot download 2014 ,13,12 ......versions now are you sure sir???
@Mark.Lancaster wrote:The 2014 version is retired by Autodesk and no longer available by download. Did you ever own 2014 in the past? If you did what was your upgrade path and that will determine if you can get a temporary link to download
