hello.today I was trying to install autocad 2013 to my laptop an I get a message for activation limit reached.I had autocad in my computer, but I had to format so I reistalled it 20 days ago again but now I have that problem.Do I have to make a new account to install it right?please response,thanks.
Solved by dmfrazier. Go to Solution.
Please correct me if I'm wrong, but since you used the word "activate", I assume you have purchased a valid, permanent license.
If so, how many times did you actually activate the software? Did you activate it more than once on different machines, or have all the activations occurred on the same machine?
Did you purchase Subscription with the software?
Have you seen this? http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=17905584&linkID=9240617&siteID=123112
Or this? http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=19820122
I'm not familiar with the rules for Student versions, but here's a place to start:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17996352&linkID=9240617#section8
Good luck!
