AutoCAD 2012 message "please wait; formatting text"
Message 1 of 13
Autocad2012 gives message as "Please wait, formatting text" and stops. The drawings will never open after killing the task also and we need to restart the system.
Suggest any solutions for this
Vijay
@Anonymous
john.vellek has edited your subject line for clarity: please wait; formatting text
Replies (12)
Message 2 of 13
jayhar
Take a look at the text styles used in the drawing, are there any unusual ones there which are being substituted?
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 13
Vinayv4v
Please upload the drawing so we can have a look.
Cheers,
Vinay Vijayakumaran
Message 4 of 13
To check that autocad itself will not open
Message 5 of 13
jayhar
please upload your cad file
Message 6 of 13
john.vellek
Hi @Anonymous,
Are you seeing this error message with specific drawings or all drawings?  What is your OS ?
Have you tried using Recover on the file(s) before you open them?
John Vellek
Message 7 of 13
jayhar
Message 8 of 13
jayhar
"There are a few ways to try to fix this. Open the text in the editor. Select all of the text (press Ctrl+A), right-click, click Remove Formatting, then pick one of the three options given: Remove Character Formatting, Remove Paragraph Formatting, or Remove All Formatting. Remove All may be what you need.
"This should clear everything out. If that doesn't work, select all of the text (while in the editor) and copy (Ctrl+C). In Windows, open Notebook (a simple text editor that strips all formatting from text) and paste (Ctrl+V) the text as a new text object."
Message 9 of 13
I have also encountered this problem for the first time in 15 years of using ACAD.
The drawing will not open, it just spins and the comment "Please wait, formatting text" shows up in the bottom right of the program screen, with the loading bar.
It continually does this. I see there are suggestions about checking text, is there any strange text etc.
the file DID open and worked for sometime, i do not know how this became a problem.
Tried running recover on it, seems to go through most checks, then when it tries to open the file, the problem occurs again.
Message 10 of 13
i have attached a screen shot
eventually the plan shows up (But i cannot do anything) and the formatting text loading down the bottom right is visible in this screen shot.
It will just do it occasionally, but i cannot do anything else....
Message 11 of 13
BeKirra
Try this command _recover
Then save it to an older format (e.g. 2013 - assuming you have the most recent AuyoCAD version).
Reopen the drawing.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 12 of 13
cadffm
Without the file I will not try to help but if you share the data I will look at it and I'm pretty sure I (we) can help.
Sebastian
Message 13 of 13
pendean
Community Legend
Community Legend
Are you still using 2012?
Is this plain AutoCAD, or a vertical version like MECH o C3D or...?
Did you fix the file yet as noted by others?
