autocad 2012 file regen continuously and hanging and aborting from the file
chakra48
chakra48
Hi to all,
I am facing another issue. I am using autocad 2012, when i open the file after got opened, it is keep on regen and i could not type command in the command prompt. I recoverd and made audit also. But there is no use. I could not copy into another file bcoz of lots of vp layers and layout setting. Do any one have any lisp to clean the same file itself.  Pls share and it get aborted from autocad Any tool can export all layer settings and import, if we copy into another file. Pls help
pendean
Community Legend
Community Legend
I don't see an answer in your duplicate post, did you miss the actions proposed to you there
https://forums.autodesk.com/t5/autocad-forum/in-my-model-the-polylines-are-filled-but-in-layout-not-...
There is nothing wrong with the file you posted, perhaps the issue is your missing xrefs,
or the "SWR_ARCHCORE" proxy content in it,
or one or more of these purgeable items
Blocks.................... | Purged : 81
Registry Applications..... | Purged : 48
Annotation Scales......... | Purged : 16
Layers.................... | Purged : 68
Line types................ | Purged : 8
Dimensions................ | Purged : 14
Text Styles............... | Purged : 31
Plot Styles............... | Purged : 11
