AutoCAD Forum
Autocad 2011 Trim /Extend command problem
4 REPLIES 4
1254 Views, 4 Replies
Hi All,
  Please help. Using Autocad 2011 and the Trim/ Extend command is not functioning correctly.
The Trim command  does cut the line but leaves it in segments and does not trim right back to the intended line. Quiet often, but not always, the trimmed line will also `jump` to the nearest end point of another line after trimming.
The Extend command will extend the line but only in short extensions at a time taking many clicks of the mouse  and not all in one `click` as it should.
What is more annoying is that both these faults are intermittent  occuring about 50% of the time.
Desperate -please help.
4 REPLIES 4
Alfred.NESWADBA
First guess:
take care about the option _EDGE for the _TRIM command and make sure that "No extend" is chosen.
If that is not the answer then a drawing might help +:
What do you mean by "another line" ... it depends which lines (or objects) you selected as cutting edges, if you just pressed <ENTER> when you where asked for selecting the cutting edges then every geometry object is selected to be a cutting edge ... and so you might have to click more often to get the line trimmed back to the edge you like to have it.
Same explanation as above.
If you select just one cutting edge (and do not press <ENTER> when asked for cutting edges) then only one mouse click should be necessary.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thanks for advice,  i`ll try it out and see how it goes.
in reply to: Jonathan3891
Hi, Thanks for advice, will try it and see how it goes.
AutoCAD Inside the Factory
