I know this is ancient technology at this point but, does anyone out there know where I can come across an AutoCAD 2002 install disk/file? We own a legitimate copy. Just seem to have misplaced the install disk. Shelling out thousands for a new version is not an option.
Solved by rkmcswain. Go to Solution.
Shelling out thoussands is not really an option anymore. You can rent current versions of Acad by the month/hear/quarter (marketed as Desktop Subscription). But you can't buy an upgrade
Or you can spoend a couple of hundred bucks for a perpeptual license of Ares Commander from Graeber, or BricsCAD, CorelCAD, or one of the intellicad variants.
Or go really cheap and use the 'free to use for any purpose' Draftsight. Since you're still on Acad 2002, Draftsight will be a nice improvement.
And yes, all the programs mentioned are DWG compatible.
We also have CAM software for our KOMO machines that was designed to work with Autodesk. I'm not sure if these would be compatible with the other programs that you've suggested. In the meantime, we'll keep looking for that install disk. I appreciate your timely response. Thank you for your help.
I still have my old AutoCAD 2002 disk. I've just got onto this as I want to install it on a new computer running Windows 10 and it is not happening.
2002 won't work in Windows 10. I had to set up a virtual machine with Windows XP. Not ideal, but better than paying thousands for a new program.
