With the recent upgrade to 2016, does anybody knwo which of the new AutoCAD PDF pc3 files are used with the Auto-Publish function?
I assume you are referring to the 'DWG to PDF.pc3' file?
If thats the case - why do my Auto-Published PDF's not publish correctly when I have copied the PC3 file from 2015 to 2016?
Dean
Don't just make a comment of 'Bad Idea' without backing it up... I asked the question of which PC3 file was used as whichever one I try to edit doesnt appear to make the necessary tweaks I require to make the Auto-publish work correctly and not clip the edges of our company drawing template.
I am sure you are aware (or maybe not) that 2015 came with one PC3 file relating to PDF's, 2016 has five.
You don't need to see my screen, you dont need anymore details - if you are a so called 'Expert' answer the question that I asked and dont assume you are better than others, who gave you the 'Expert' title anyway?
I look forward to a geniune reason (backed up by fact) that copying a PC3 file from 2015 to 2016 is a Bad Idea and if you are the font of all knowledge - answer the question.
I had a similar probem in that every time i save the pdf is published and then opened with my default viewer i dont want the PDF opened. I know in the pc3 files there is a check box "show results in viewer" I have this unchecked in the DWG to PDF.pc3 (which was the old file for 2015). This did not fix the problem, there are 4 other pdf pc3 files General, High Quality, Smallest and web. I went through and unchecked them one by one and it is the AutoCAD PDF(General Documention). my only niggle now is i can't find anywhere in the options where i can choose which pc3 file to use for the autopublish, there seems only to be PDF, DWF and DWFx. Does any know where to change this.
It is the automatic publish i would like to now how to change which pc3 file it used.
under the options, plot and publish tab, Automatic publish settings (automatic publish check box ticked), file format, their are 3 choices PDF, DWF, DWFx.
I tried the publish command it has the same 3 settings PDF, DWF, DWFx and plotter named in page setup, which is set for my printer.
My question is there must be a setting that lets autocad know when the autopublish is run which PDF pc3 file to use, their are 5 PDF pc3 files now with autocad 2016. I also now it is set to use the general documention.pc3 file as i can change settings in that file to change my results. May be I want to use the highest quality print.pc3.
I keep 2 files of my drawings the dwg and a pdf. the autopublish is great as it keeps my pdf's up to date.
May be i haven't explained well enough, I don't have any trouble with the .pdf opening anymore as i turned off the option in the general pdf file so it now does not open the pdf viewer when i save(and that is how i know what file the autopublish is using). My question is how do you change which pdf file the autopublish uses (noting autocad has provided 5). Currently set to the general file. Can't find any settings to change this. Is their one? Its actually not a big problem, i guess i like to know how to change things.
Cameron
I don't think Dean 'the expert' understands what you or I are asking. From what I understand of your posts, you are questioning which PC3 file is used for the autopublish function that creates either a PDF (or DWF when that option is chosen) when either saving or closing a drawing.
From what I can tell from your latter posts, you have found which of the PC3 files that creates the PDF as you say you have managed to switch off the auto-preview. I have had a good look through the system variables and cannot find anything that allows the user to change the PC3 file used and as you will have found, there is nothing in the auto publish settings dialog box to change this either.
Regards
Andy
Thanks for the help no need to keep looking,just for interest I renamed the AutoCAD PDF (General Documentation).pc3 to see what would happen and sure enough there was an error when I saved the drawing but still no way of changing or selecting another file. so it defently uses this file and not the old DWG to PDF.pc3 file.
