AutoCAD Forum
Attributes
10 REPLIES 10
Message 1 of 11
marthaA8SAZ
594 Views, 10 Replies
Attributes
marthaA8SAZ
Can a suffix from an attribute be removed globally?
Attributes
10 REPLIES 10
Message 2 of 11
cadffm
in reply to: marthaA8SAZ
cadffm
is it unique in the attribut values?
Then use FIND &replace.
Otherwise, use ATTOUT edits with Excels and ATTIN
Sebastian
Sebastian
Message 3 of 11
JTBWorld
JTBWorld
You can also use our JTB BatchAttEdit, export to Excel, do your find and replace and import back.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Jimmy Bergmark
Message 4 of 11
marthaA8SAZ
in reply to: cadffm
marthaA8SAZ
It is not unique to attribute values; it's within the additional format window after the Field box. Thank you for the suggestion jtbworld. I thought that this could/should be answered by AutoCAD and not have to purchase an outsource program to resolve.
Message 5 of 11
cadffm
cadffm
Share a sample (dwg) ,
and mark what you like to remove.
Sebastian
Sebastian
Message 6 of 11
JTBWorld
JTBWorld
Autodesk usually don't reply here to questions.
You can always do it manually with no other apps but sometimes you can do things quicker with help of other apps.
Can you send a screenshot indicating what you want to change and where?
Jimmy Bergmark
Jimmy Bergmark
Message 7 of 11
ChicagoLooper
ChicagoLooper
@marthaA8SAZ wrote:
<<.... it's within the additional format window after the Field box. ....>>
Go to the 'additional window' and clear the part you want to delete. Or if it's a dropdown, select 'none' from the dropdown list. Click OK.
Chicagolooper
Chicagolooper
Message 8 of 11
marthaA8SAZ
marthaA8SAZ
I'm aware of where to go to change or delete the Suffix. My question was/is if it was possible to do a global change all the blocks so that I don't have to go into each attribute one by one to change it.
Message 9 of 11
ChicagoLooper
ChicagoLooper
No, not possible because the suffix is part of the field.
There is no global command that will modify a field because, by definition, a field varies from instance-to-instance, or from block-to-block.
Chicagolooper
Chicagolooper
Message 10 of 11
JTBWorld
JTBWorld
It would be possible to create a custom command that does what you look for but it is not possible out-of-the-box. If you have really many you need to change it might be a ROI to have it created. If so, feel free to contact us directly. See our website under contact.
Jimmy Bergmark
Jimmy Bergmark
Message 11 of 11
marthaA8SAZ
in reply to: JTBWorld
marthaA8SAZ
Thank you for the offer. I'll keep it in mind. For now, I'll stick to simply omitting the suffix to begin with.
AutoCAD Inside the Factory
