Attributes with suffix
Does anyone know if I can pre-set suffix ("m²") so as I don't have to manually enter it in each instance of attribute?
MMcCall402
You could add it into the default value of the attribute as text after the field.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Thank you, that solves the problem with typing it in in each instance. But since it is in the same space where I have to ADD FIELD, it makes the process slow. I have to pay special attention to not to click on the "m²" when adding the field. I hope Autocad will improve this function in the future!
ara_neresesian
Hi
you can put m2 in the block (this is a trick but it will solve your problem)
i am sending a cad file as a sample (dont forget to set your att.  justification to the right)
Good luck
Thank you, this is what we are using at the moment but these get off center with bigger areas and drawing does not look that presentable with some numbers jumping off center.
vinodkl
Here is what your looking for : Suffix attribute with m2
Replace the tag "AREA" in the lisp with your attribute tag.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ara_neresesian
HI
Please make a screen shot "get off center with bigger areas"
or upload the area with attribute off center in cad file.
good luck
