Attributes and Character Spacing
We have a title block with attributes using a truetype font in AutoCAD 2007.  After doing a regenall the space between the characters expands by approximately 1.5x.  This also occurs when printing.
While troubleshooting I noticed several quirks:
1. The spacing problem only occurs with truetype fonts.  Not .shx fonts.
2. This does not happen when the block in in modelspace.  Only paperspace.
3. It only seems to happen with attributes.  Not with mtext or dtext.
In the attached bipmap, the attributes which appear correctly is on the left and in modelspace.  The attributes that are problematic are on the left and in paperspace.
pendean
Community Legend
Community Legend
Are you sure that's a feature of the font you are using in the attributes?
What is that TTF font?
The TTF is Gill Sans but I doubt the problem is related to the specific
font as the issue occurred with other TTF but not with .shx fonts.
pendean
Community Legend
Community Legend
What spacing setting is the attribute set to? Change it to 1 and see if the problem goes away.
The text spacing is set to 1 in the style setting.
Alfred.NESWADBA
Are you sure it's a true type font? I just opened MS-Word, looked for that font and this is an OpenType-font, not a TrueType-Font (on my system)
Which operating system do you have?
What happens, when you start command _STYLE and adjust the width-factor to 0.95 or so (close to the current setting, but a bit different).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
