Attribute Extract Error BL:Name
deirdremooresomers
Observer Observer
deirdremooresomers
Observer
Observer
I have recently added authoring elements to some blocks I use to alter the location of the item with reference to its tag.  Previously I extracted info from these blocks including the names of the block which identifies the item type. Now when I run ATTEXTR I just get *U for the name of my block (BL:NAME C039000). There are several different named blocks in my drawing, they all get labelled *U.
All the other information is extracted as expected.
BL:NAME C039000
BL:LAYER C050000
LOOP_NO C015000
ITEM_NO C015000
ROOM_NO C050000
ROOM_DESC C050000
BL:X N015001
BL:Y N015001
BL:XSCALE N009002
BL:YSCALE N009002
BL:ORIENT N004000
paullimapa
If you have dynamic blocks then you'll get *U in the block name.
Paul Li
IT Specialist
@The Office
cadffm
additionally for dynBlocks
Blockreference of dynBlock will refer to your original (named) Block,
until you change dynamic parameter values. Acad will create a variant block
with the anonymous name *Unnn
You are posting in AutoCAD forum, in AutoCAD nnnn and AutoCAD LT 2024+
use a better 3rd party Tool. There are a lot of them available.
For AutoCAD (not) LT, command DATAEXTRACTION (EXTRACTDONNEES) works too.
And for AutoCAD LT 2023 or older, create an Attributedefinition with a field(block placeholder) for block name.
Sebastian
