Attach/xref/open a dgn sheet in AutoCAD
Greetings
I'm using AutoCAD 2019
Is there a way to attach/xref/open a microstation dgn "SHEET/layout" in AutoCAD.
The only option I see to "open" a microstation file is the "design model" option, but no sheet/layout option.
When trying to attach/xref a sheet file I get the following popup. None of these items are applicable because I can open a design model of the same project.
Thank you
Gabriel
john.vellek has embedded your image(s) for clarity
john.vellek
Hi @Anonymous,,
Quite honestly I am not sure this can be done.  If you can share the Microstation file though I am happy to see if it is possible. I have both Microstation and AutoCAD on  my computer and I suspect an "Export" from Microstation will be required.
If your data needs to be private or confidential, please email it directly to me at [email protected] and please include a link to this thread in your email.
John Vellek
John,
Thank you for your reply. I presumed that it might not be possible. I was moving away from having the client provide the translation because I was ending up with only continuous lines for all layers and no line styles, and not until recently I was able to open a dgn with a healthy % of correct line styles.
I will email you a file.
Thank you for looking into this.
Best Regards
Gabriel
john.vellek
Hi @Anonymous,
I tried a variety of things such as saving down from Microstation as well as some export options.  I did not have any better luck than you have been experiencing trying to get this to work.  I imagine the sheets in the Microstation drawing are similar to AutoCAD paperspace layouts which also cannot be xref's or inserted. I am not terribly familiar anymore with Microstation but let me do a bit more research to see if I can find any other options.
John Vellek
Sounds good. Thank you.
john.vellek
Hi @Anonymous,
I have received confirmation that AutoCAD only works with the Deign Models and not the sheets.
You are welcome to contact the product team directly. If you have additional comments specific to the software or its functionality for future consideration, please use the Product Feedback page. How to provide feedback on Autodesk products goes into more detail.
Another great option is to participate in the AutoCAD Customer Council. This is an opportunity for our customers to partner with the AutoCAD development team to improve future releases of AutoCAD by giving continuous feedback on ideas, designs, and early builds.
In order to get involved email [email protected] or [email protected]
John Vellek
John,
Thank you for your prompt responses. I will contact the product team as suggested.
Best regards
Gabriel
