ATTACH Dialog Box is Missing
autocad_035NVMP
autocad_035NVMP
Community Visitor
Community Visitor
Dear all,
I'm a new guy to use Autocad.
I found that I'm missing  a "Attach" Dialog box, How come?
I checked "FILEDIA", is <1>.
Please help.
Thank you and waiting for all kindly reply.
cadffm
"ATTACH" dialog of what command?
What do you like to "attach", a DWG PDF JPG DWF XLS - what is it?
for example, command ATTACH
type in
ATTACH<Enter>
If you can't see a dialog to choose fileextenstion and file, it is offscreen and you can work on after [ESC] only.
Is that the case?
Start command ATTACH
press [ALT]+[SPACE]
hit [M]
hit one of the arrow-keys (not from the numpad)
and move your mouse
the dialog should follow your cursor
Sebastian
imadHabash
Hi and Welcome to AutoCAD Forum,
If your problem still exists with this command and any other ones ... I suggest to reset  AutoCAD for default settings. >> Click <<
Imad Habash
pendean
Community Legend
Community Legend
CMDDIA variable set to 1 as well? @autocad_035NVMP
Or does the program appear to be frozen when this pop-up is missing?
AllenJessup
By Attach do you mean the External Reference Manager or possibly Insert. The Attach command on the command line does not open any Dialog box. It opens a browser to select a file.
Allen Jessup
CAD Manager - Designer
BhaskarMurari
AutoCAD-specific troubleshooting
  • Be sure that the FILEDIA and CMDDIA variables are each set to a value of 1. Type them in on the command line (separately) to check their current value, and set to 1, if necessary.
  • Reset AutoCAD to defaults: How to reset AutoCAD to defaults.
  • If this does not resolve the issue, fully uninstall and reinstall the affected Autodesk product: Clean uninstall of AutoCAD or verticals
For more help refer this article Dialog box windows are not displayed in AutoCAD products
paullimapa
Does this help:
Press the tilde symbol on the keyboard and then <Enter> to bring up a selection window
Paul Li
IT Specialist
@The Office
