Attach Block to mouse cursor
csteeleU2Z9C
csteeleU2Z9C
I have a very large project to complete for my job in a short space of time.
Is it possible to attach an AutoCAD block to my cross-hairs using a hot-key?
Clicking and dragging from a palette is too slow.  I need something faster.
Say #1 on keyboard gives me one block and #2 gives me another block.
ВeekeeCZ
You can do that using a LISP. Here's an example of code for 1.
(defun c:1 () (command-s "_.-insert" "block-one" "_s" 1 "_r" 0) (princ))
block-one must already be in a drawing or stored as block-one.dwg at a searchable (support) file path.
Here's the manual on how to load it.
https://www.lee-mac.com/runlisp.html
imadHabash
Can you tell us what is slow in such a procedure?
Imad Habash
AllenJessup
If you copy a block. CTRL+V will paste the block each time until you copy another block of entity.
Allen Jessup
CAD Manager - Designer
Kent1Cooper
The suggestion in Message 2 defines a command, which means it would be necessary to type the 1 and Enter to register it.  But there is a single-keystroke possibility, though it involves more than one key, but at the same time [no Enter required].
You can define a Shortcut Key such as Ctrl+Shift+Z to fire up an Insert command with a specific Block name, spelled out as in Message 2's command, but in command-macro rather than AutoLisp format.  Then you can just hit that key combination and place the Block.  Read about creating keyboard shortcuts under the CUI command.
[As in Message 2, there must be a Block with that name in the drawing, or a drawing with that name to become the Block, in some location where AutoCAD knows to look.]
Kent Cooper, AIA
