Associate Scale of ViewBase Block
Chirpyboy2060647
Chirpyboy2060647
Im curious if there is a way to make it so when i edit my text block, that i can associate the scale of my ViewBase model so that anytime i change that initial view itll update my Scale. Ill attach a picture to try and show what im trying to get associated with the View.
Alfred.NESWADBA
you can create a field, based on "Object" ==> select the viewbase ==> standard scale ... that should it be 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Chirpyboy2060647
Wow thanks this is a good start. I tried to replicate your image you posted, but when I select the Object Type it comes out as Block Reference. From there i dont see a Scale minus Scale X/Y/Z.
Ok nevermind i think i got it. I was selecting the block instead of the view.
How did you select the view?  It is invisible, is it not?
