arrow flip
arrow flip
arrow flip
 I connot (no matter how hard I try) find the arrow flip command. I need to have the arrows flipped from outside to inside on a linear dim. or else I will not be able to see my work. the flip command is not on my right click tool bar. I am using autocad 64 bit 2016
imadHabash
Hi and Welcome to AutoCAD Forum,
>>  I connot (no matter how hard I try) find the arrow flip command. <<
when you hoover your cursor over the grip and after select the dimension a pop up will appear to find it there. see below image
Imad Habash
Vinayv4v
You can select the dimension and iin the grip edit there is option to flip each arrow separately.
Or you can use the command AIDIMFLIPARROW.
Cheers,
Vinay Vijayakumaran
thanks
thanks to you both!!!
john.p.addy
I know this is an older post but I'm having this save issue.  I did the flip arrow like shown above but now I'm getting line outside which I have circled in blue.  Is there a way to do away with the line
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
