Array aprears to be block when edit in place (REFEDIT)
avishay86MGE9
Observer Observer
avishay86MGE9
Observer
Observer
I encounter a problem edting arrays that are included in block.
1. I create a path array.
2. Selecting both the array and the PL that serves as a path.
3. Edit block in place, array shows as a block.
     when using Block edit- array stays array.
editing the block without reference is useless for me in this case.
please help!
Valentin_CAD
@avishay86MGE9 ,
Welcome to the AutoCAD forum.
AutoCAD is working as intended.
Please elaborate you intention.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
@avishay86MGE9 Do you just need to change your ARRAYASSOCIATIVITY variable setting? Usage is explained in HELP https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-298A0544-E6C3-496F-9FA1-12AEC2FF564....
Or do you just need to use COPY command's "array" sub-option instead of array command
https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-1CF9287F-06E8-4D03-8377-2E130862FE0....
avishay86MGE9
Observer
Observer
thanks pendean.
I'm trying to reserve the path guiding line in order to be able to change the array's path.
I can't understand why array in a block is acting like a block... and in evidance- it's acting like it ONLY when editing in place.
cadffm
>>"I can't understand why"
Because: IT IS!
The visual displaying thing on screen is displaying by a block reference, a very special one, but still a block reference.
Side note: You can use XCLIP on Arrays too, because of this.
While in 'editing in place' mode, it isn't hidden enough 😆  - and array edit  isn't implemented.
Sebastian
ВeekeeCZ
Well, REFEDIT is generally considered obsolete. So they probably just didn't waste their time to allow full capability.
