Area
Area
Area
Hi all. I am calculating area. I made a square 0.25 x 0.25. Then i used area command. The answer is a whole number and no decimals so it says area=0. I know i can manually solve it but to irregular shapes who have big areas not showing the decimal might be a big discrepancy. I want the command output to show the decimal places. I need your help guys.thank you.
imadHabash
Hi and Welcome to AutoDesk Forum,
DDUNITS is your need, just change the Precision.
Good Luck..
Imad Habash
thank you so much.
