Are .ctb and .pcp files accessible in any version of Autocad?
marcbartolucci
marcbartolucci
Im using Autocad 2019 and sending a file to someone with Autocad 2017. I saved the actual CAD file down to 2013, but what about the .ctb? is that also affected by the different versions of autocad? I am wondering the same thing about .pcp files
pietro.pedone
Autodesk Support
Autodesk Support
Hello @marcbartolucci , backwards compatibility for these files is not a problem--in fact, I'm pretty sure that if you look into your "Plot styles" folder you'll find very old CTBs. However, PCP files will have to be converted to CTB files before using them in more recent versions of AutoCAD.
Hope this answers your questions, and if so, please accept this answer as a Solution 🙂
Pietro.P
Global Product Support
Autodesk Knowledge Network
lthomasGND2L
Community Visitor
Community Visitor
How do you convert a .pcp to a .ctb on a Mac?  I cannot find a solution that works. I have been searching and trying for hours.
Thanks!
cadffm
There is no function to do this in AutoCAD (LT) for MAC.
You can use AutoCAD (for windows) up to version 2023
(Command PCINWIZARD  is obsolet in 2024)
Sebastian
