Arctext not plotting with Publish Command
MaryCaldera
MaryCaldera
Hello, since the AutoCAD 2022 update earlier this year any arctext content just displays as a box if I plot with the Publish function. It comes out fine if I plot layouts individually, but that is very inefficient and our office needs to publish all at once. I have not found any references to anyone else having this issue on any forums. I once uninstalled and reinstalled CAD from our original download content which solved it for awhile until it automatically updated again >.<
pendean
Community Legend
Community Legend
Never seen that before: this happens in ALL files or just this one? For all of you running R2022 or just a few?
Share your DWG file here please, we all are running R2022.1.2 with no ARCTEXT issues like that.
cadffm
Publish in foreground too, or only by background publishing?
Sebastian
MaryCaldera
Thank you, I had Publish in Background selected and removing that to publish in foreground worked.
I am still confused why the change because I have always used Publish in Background prior to this and never had that problem.
MaryCaldera
It was happening to any file with arctext, not only that one. I cannot share the files as they are since they are seals from my workplace. I tried setting publish to foreground based on another suggestion and that is working correctly for now.
pendean
Community Legend
Community Legend
@MaryCaldera background publishing may not be loading Express Tools first, a requirement to see ET content like ArcText.
Glad you shared your solution with us: no one in our offices uses background publishing, a bunch of control-freaks that need instant results 😉
