arcs change to circles when xrefed
Message 1 of 20
I am having a rather annoying issue with a number of arcs with a topographical survey.
Within the survey drawing the lines appear as drawn with no issues at all, however as soon as I xref the topo into my site plan the lines expand into circles. I have tried multiple regen's and changing the pdmode from 2 to 1 or 0 but nothing is working.
Please can some one advise as to what might be causing this.
I have attached a screen shot of the topo as normal and one of it xrefed into my drawing.
Update: I have tried turning off smooth edges in GRAPHICSCONFIG which solves the problem but then turns the arcs in the rest of my drawing into a straight lines.
Many thanks,
Dave
Replies (19)
Message 2 of 20
Alfred.NESWADBA
Am I correct that after you run command _REGEN you do have the display of arcs corrected?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 20
rkmcswain
Sounds like a display driver issue. Are you running a supported adapter with the recommended driver?
As a temporary workaround, try disabling hardware acceleration.
Message 4 of 20
Does regen work
Message 5 of 20
Hi Alfred,
Unfortuantely no.
I have tried regen multiple times with the arcs remaining a straight lines after turning off smooth line within the graphicsconfig menu.
I don't know if its worth noting or not but I am unable to turn off smooth line without turning off high quality geometry.
Message 6 of 20
If I disable hardware acceleration I have the same problem as turning off smooth lines.
It solves the problem with the arcs in the xref however the arcs in my drawing become straight lines which causes more issues
Message 7 of 20
chriscowgill7373
Check your Display Resolution settings within the Options Dialog -> Display tab.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 8 of 20
Alfred.NESWADBA
Do you first run _REGEN and then ZOOM to see how the arcs are displayed ... or do you first ZOOM and then run _REGEN (second option is the correct workflow).
I can't imagine that arcs are then displayed as lines.
- alfred -
Alfred NESWADBA
Message 9 of 20
I zoom then run REGEN and the lines do not change back to arcs.
I have attached a screengrab of one of the areas effected.
This is after I have zoomed in and tried regen.
Message 10 of 20
Alfred.NESWADBA
Strange ... by any chance: are the coordinates at very high values (> 10^6)?
Can you upload the drawing so we can test these objects on our systems, just to see if that is something drawing-specific and happening on our systems too?
- alfred -
Alfred NESWADBA
Message 11 of 20
Hi Alfred,
I have uploaded the file in question as a dwg.
Thanks.
Message 12 of 20
rkmcswain
Can you please tell us what model display adapter you have and the driver version? If one or both are not on the certified/recommended list, the symptoms you are describing can happen.
Message 13 of 20
Where would I find this information please?
Message 14 of 20
rkmcswain
Run the GRAPHICSCONFIG command, snapshot the dialog, attach here.
Example below.
Message 15 of 20
I have attached the graphicsconfig below
Message 16 of 20
rkmcswain
Unless I overlooked it, we do not know your O/S or AutoCAD version. So I can't look it up, which is why I included the link in post #3 to the Recommended hardware/driver list.
Message 17 of 20
I am running windows 10 and my autocad is LT 2017
Message 18 of 20
Alfred.NESWADBA
have you seen post 10 in this thread and verified the coordinates?
That are your coordinates:
X = 608680518.2573     Y = 238580124.3342
And these high values are very close to the limit of double precision calculation.
Scale your drawing by 1/1000 and set your units to Meter instead of Millimeter and all is well 😉
- alfred -
Alfred NESWADBA
Message 19 of 20
Hi Alfred,
Unofrtuantely we only work in millimetres as an architectural practise.
We had to scale the os by a factor of 1000 to covert it to millimetres and then xrefed in the topo. We then repositioned the os data to suit the topo position which came in at those coordinates.
Is there anyway to solve the problem without converting the drawing back to meters?
thanks
Message 20 of 20
Alfred.NESWADBA
Your coordinates are too far away from 0,0 and with such high coordinates you'll get less digits (behind the decimal separator) for mathematical calculations. That's not a limit of AutoCAD, that's a limit of double precision/how coordinates are stored in CAD-systems.
Also these high coordinates not only have issues with the display, also with commands like TRIM or EXTEND, with object-snap like INT and a lot more...
You can stay in Millimeter, but then you need to move your geometry to 0,0 ... and if you want to have that dwg at correct coordinates I can use XREF to insert your drawing (close to 0,0) and move/rotate/scale the referenced object to the correct location.
If you work in Meter, you won't have all that issues.
- alfred -
Alfred NESWADBA
