Arc Text on BOTTOM of arc
Paul.Devitt
Paul.Devitt
Autocad 2019
I need to create some arc text for laser cutting and I cant figure out a solution to put it along the bottom of a circle or arc. I can create arc text for above an arc but not under a design in a lower arc so to speak. In the attached picture, "BACK ALLEY" was created with arc text, but "CRUISERS" had to be created as a straight line of text and I then had to rotate and move them as single letters, it is VERY time consuming, is there actually a way to get this done like the upper arc text or am i screwed?
Thanks.
Paul.Devitt
i accidentally created this topic twice, cant figure out a way to delete one, maybe an admin can delete one for me, sorry.
S.Faris
Check the GIF
SALMANUL FARIS
Paul.Devitt
S.Faris, no, look at my attached picture, I need an arc in the shape of a "smile" , not a "frown"
S.Faris
Check this
SALMANUL FARIS
Paul.Devitt
i tried that and my text is ALWAYS backwards
Paul.Devitt
Finally got it to work, I had to select the "inward to center" option.
